Results 1 to 7 of 7
Thread: 1 inch to 1.25 inch Tank Connection
    DIY Junior Member
    Feb 2009
    Downingtown, PA
    Default 1 inch to 1.25 inch Tank Connection
    I am replacing my tank.
    I checked the connections from the supply line coming into the house to the tank itself.
    Everything is 1 inch.
    The connection on the tank I would like to get is 1.25 inch.
    Will there be a problem adapting the 1 inch connection up to a 1.25 inch connection?
    If you decrease the size of a connection the pressure increases, if you increase the size of a connection the pressure decreases.
    Am I correct?
    So how will that affect the tank or the overall pressure of the system?
    If it will cause a problem I will need to choose a tank with a 1 inch connection.
    Any comments on the subject would be appreciated
    DIY Junior Member
    Feb 2009
    Downingtown, PA
    yes, the pressure tank
    DIY Junior Member
    Feb 2009
    Downingtown, PA
    Nope, not going to re-pipe.
    I just want to make sure that shifting from 1" to 1 1/4" won't cause some problem with the pressure in the tank.
    Jan 2008
    Smile
    Actually, it would not matter if it was 1" or 1/8", the pressure does not change.
    It is common to have 1-1/4" pipe coming from the well. Reducing the size to 1" anywhere in the system will have no effect on an average single-family sized home.
    Consider that most main supply piping in the home is 3/4". Water heater inlet/outlets are 3/4 inch.
    Your problem, is not a problem.
    DIY Junior Member
    Feb 2009
    Downingtown, PA
    my situation is the opposite
    the pipe would go UP in size from 1 to 1 1/4
    wouldn't that reduce the pressure going into the tank?
    (this is all because the people who put it in were too cheap too spend an extra couple of bucks to use 1.25 pipe like you're supposed too - it's frustrating)
    Jan 2008
    No, fluid pressure is NOT effected by the size of the pipe. If it's 50 psi coming in, it's 50 psi coming out. The pipe size variance you are talking about is common.
    Do the work, there's no problem.
    DIY Junior Member
    Feb 2009
    Downingtown, PA
    It's all done
    Works Great!
    Thanks a million for your help
