Thread: Drip irrigation of groundcover
    Engineer jdkimes's Avatar
    Littleton, CO
    Default Drip irrigation of groundcover
    Maybe more of a landscaping/gardening question:
    I live in Colorado and have quite a bit of xeriscape (low water landscaping) groundcover and use some dripping irrigation. But what's the best way to water a larger area of groundcover (6x25) with a drip system?
    I know there are a lot of drip pipes/tubes but should I just lay them on top of the ground cover? How far apart to lay them? or do I try to put the pipes on the ground?
    Plumber jimbo's Avatar
    Toro makes a 1/4" drip tube with 1/2 GPH emitters every 6" You could easliy snake this through the ground cover (under the canopy) in a pattern which would water adequately. It would not be visible if you work in in under.
    Default drip
    You can use the pipe with integral emitters, or use soaking hose in a serpentine pattern, or use the small spinning emitters.
