Results 1 to 6 of 6
Thread: Got a Toughy! Electrical Box Cover
    Default Got a Toughy! Electrical Box Cover
    Hello All,
    I have the misfortune of trying to put an electical box cover over a set of plugs that is embedded in a rock face. I purchased a Nylon cover that claims is unbreakable but it catches on the protrusions from the rock face.
    So either I'm going to need a cover that is vitually the exact size as the box or I need one that is pretty much made out of rubber.
    I have a Nylon cover. Can it be cut?
    Tom
    It should be able to be cut, as long as you don't use something like tile nippers. I know that the plain metal covers are a very close fit on some boxes. They need to be to be used for exposed work. Otherwise could you put a box extension on and bring the box out flush with the highest point of the stone?
    I consider myself an accomplished DIY'er. I don't know everything but help where I can. I'm not a pro, but like to think I'm professional.
    So what should I use to cut the cover?
    Any other ideas?
    Tom
    You can cut the nylon cover easily with tin snips or just about antrhing.
    A metal handybox cover will be smaller.
    I'd like to see a picture of this!
    Thanks for the tip on using the tin snips! Work like a charm. I was even able to cut little slivers off to fit the cover. I had my doubts to be honest.
    Is there a size limit on pictures? If not I will post one.
    Tom
