BurleyMike
I started cleaning out the garage and got to thinking about the ceiling. The problem is the ceiling joists are 21' long 24" OC 2x4s. The big problem is the one of the previous owners put 1/2" sheetrock up there and then 10" of blow in fiberglass on top.
As you can imagine the whole ceiling is sagging about 6" in the center. I want to mud and tape the seams on all the drywall out there but I know this needs to be done first.
The span for the beam will also be 21' the garage is 21x21. I will have to build this beam myself out of dimensional lumber for a few reasons. I would love to just use a gluelam.
On one side I have a window and the other a door. I can't just slide a beam up into place because of these obstacles. I plan to use scaffolding and assemble a beam with dimensional lumber above the window and door.
I know I will need to build a beefer header above the window and door.
The attic above this garage will never be used for storage because of the insulation and the low roof.
One solution I thought about was to attache the ceiling joists to the rafters. I feel that the roof is already overloaded. THere are two layers of asphalt and a concrete tile roof sitting on those rafters. Yes I am planning on doing a tear off on the roof.
Sorry for the long post, I am no good at being short and sweet.
