Hi, well this will be the 3rd time I will have to "fix" the copper joint seal. B/C I ran water to test it, I know I have to take it apart (which I had done before) and clean it. The last time, it was a son-of-a-gun to pull apart and then the solder stuck to the pipe and fixture like glue. Had a heck of time to getting the solder out of joint and pipe so that the pipe would slide in.
So is there a limit to the number of time copper or brass can be reheated? I'm going out to get fresh flux and brushes just to reduce the chance of failure. Thx in advance.
