Rich B
DIY Senior Member
I have a 2 family home with all 4" cast iron dwv. There are 2 bathrooms on the second floor, back to back. One 4" cast iron horizontal run serves both. 2 toilets, tubs and vanitys. The horizontal run is about 6 feet to the main vertical stack. I need to replace the entire horizontal section and can also remove most of the vertical run down to the basement and up to the roof vent. The horizontal run has improper pitch and that is the main reason to do this. The pitch is actually going the wrong way and water is not draining from the toilet furthest from the vertical stack! This has worked with zero problems for the nearly 40 years I've owned the place. I have gutted the kitchen below and found this condition. My question is can I use 3" and transition to the 4" C.I. in the basement? The difference in pipe diameter would give me considerably more room to do this. I am a little concerned that 3" would not work as well as the 4" has for all these years.....Thanks....
