Results 1 to 12 of 12
Thread: 4" Cast Iron Pipe: Unplug Sections
    Default 4" Cast Iron Pipe: Unplug Sections
    How difficult is it to separate one section of 4" cast iron from another section. Is the oakum & lead stuff really tight? If I can unplug, then I do not have to cut the cast iron. I found flexible rubber pipe coupling that fits the 4" PVC on one end and the other end fits the "socket" female end (where the lead and oakum goes) of the cast iron pipe. No cutting.
    -xroad
    Slim to none...you can't pull a properly done lead/oakum joint apart.
    Ooh-Kaay .... Thanks .... That idea got shot down. Back to diamond disk.
    Plumbing Contractor C NUMB's Avatar
    Jan 2009
    NPR, FL
    If you have access to a sawzall ( recriprocating saw) lennox makes a diamond blade that will give you a clean cut.
    I'd Rather Be FISHIN'
    Default lead
    You can melt the lead and pull the pipe out, however. Assuming you have space to pull it.
    Nov 2008
    Chicago, IL
    Some rental places rent the chain cutters for snap cutting cast iron.
    DIY Senior Member thezster's Avatar
    Jul 2005
    Fort Collins, Colorado
    Default Done both ways
    Rented the snap cutter - and it worked great where I had the space to use it...... Used the Sawzall in tight spots... Actually got a cleaner cut with the Sawzall......
    It's 9a.m. Let's have a beer!
    Default cut
    quote; Actually got a cleaner cut with the Sawzall
    That is to be expected, but since cast iron does not need a "cleaner" cut, the snapper works better and faster.
    Nov 2008
    Chicago, IL
    This is the best snap cutter I ever owned. I like the fact I can take of the orange handle to make it fit in tight places.
    I am exploring various options. Cutting disk, sawz-all, remove lead/oakum, snap cutter ....
    Spoke with a plumber. He said depends on the workanship of the lead/oakum. Sometime it can be a bitch to get it out, sometimes easy. Snap cutter is risky. The section of cast iron pipe I need to remove is already cracked. Probably bad casting from 100 years ago. Not much left at the "good" portion of the pipe. Cannot risk the pipe collapsing under the snap cutter. So, going with the diamond disk and sawz-all.
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    That tools is "da bomb" ratz! Me likey likey! lol
    The diamond "discs" won't go on a sawzall. You need the diamond blade made for cutting CI.
    Quote Originally Posted by kingsotall View Post
    I have diamond cutting disk, for my grinder. Also carbide disk as well. Dimond blad for the sawz-all ready. I'll be testing all on a scrap cast iron elbow first.
