Results 1 to 3 of 3
Thread: Need advice on sprinkler valve
    Default Need advice on sprinkler valve
    Does any manufacturer make a 12v DC operated sprinkler (water)control valve that is 1 1/4" NFPT ported on both ends? My local big box stores certainly don't have them and before I go running around searching I thought I would ask. Thanks, David
    Plumber jimbo's Avatar
    You could easily use a 1" valve an bush down to the 1 1/4". The bigger problem is why do you need to operate on 12 VDC?? Seems almost all irrigation valves are 24 VAC.
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    What is the water pressure at this valve? There might be a standard valve that will work.
