Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: newbie
    DIY Junior Member JoeT's Avatar
    Oct 2007
    Scranton Pa.
    Default newbie
    Hi, I'm new to the forum. I have a question that may have been asked hundreds of times....I did search. My plumber roughed in my new bathroom with pex. I have no idea what type of connectors to use. I need to connect my shower mixing valve and don't know what to look for for the transition from pex to copper. Right now he left the pex capped so I could turn the water on to other areas. Thanks in advance.
    Joe
    Joe T
    Dec 2007
    Asking that question I know you don't have PEX tools...
    Do you know how to sweat copper pipe?
    Default Pex
    There are so many possibilities that we do not know which one to suggest without seeing the job itself.
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    Sharkbites are allowed in concealed locations now right¿
    Oct 2007
    Scranton Pa.
    Redwood, no I don't have any pex tools....and yes, I can sweat copper. HJ I'm new here, so I don't know if I can post a picture yet. The plumber roughed in a sink, shower and toilet valve from my basement off of existing copper, with pex. I'm getting ready to drywall the bathroom, and want to get the diverter valve and stub out for the shower head in place and would like to do it myself if I can. I've done plenty of copper, but never any pex. Should I just have him come back and finish this? I don't want to spend a lot of money for a tool I'll most likely never use again. Thanks for the replys
    Joe T
    Yakima WA
    Although PEX seems to be the coming thing in piping, I would suggest you pull it out and use copper. Two reasons I say this. First, you already know how to do copper. Second, copper has proven itself over many years.
    Dec 2007
    Joe what I would do if I was in your shoes is sweat in the shower valve with copper then connect the copper to the PEX using a sharkbite coupling. These are push fit couplings that are approved for inside walls
    Oct 2007
    Scranton Pa.
    Thanks Redwood, that's what I'm looking for. Do you know if these are available at the big box places, or should I hit a plumbing supply? Gary, thanks for the input, and I see your point, but it would be a major undertaking to remove the pex and do it in copper, I think this is why my plumber chose the pex. I'll have access to the "wet wall" in the shower through a panel in the next room. Thanks for the input folks, I appreciate it.
    Joe T
    Dec 2007
    Big Orange Box carries them as well as many hardware stores and supply houses. I would basically just use 2 of them to make the connection between the copper and the pex supplies. The valve inlets and outlets should be copper and secured well in place at the correct depth in the wall. The sharkbites do not allow much support as the tubing can rotate in the sharkbite connector.
    PEX running down to the tub spout is a no-no with many tub/shower mixers. It may cause water to flow out of both the tub spout and the showerhead when the tub spout is selected for operation.
    Oct 2007
    Scranton Pa.
    Thanks Redwood. This is just a shower so it'll be just to the mixing valve. Is there something I could use to cut the pex beside a pex cutter? If I could cut a level, flat line, with a utility knife, do you think that would be ok? The pex only comes up through the sill about a foot and is capped, so I need to cut the caps off. Thanks again for your help.
    Joe T
    Dec 2007
    The knife is fine. Just get it straight.
    Oct 2007
    Scranton Pa.
    Thanks again! Any good sources on line for shower parts? I'm looking for a basic 2 handle rough in valve. My big boxes don't have very much of a choice...and plumbing supplies are closed by the time I get out of work. I don't want to spend a fourtune for a thermostatic, or pressure balanced valve.....it's a second shower.
    Joe T
    The shower will not pass code and could give you problems with both the building inspector and when you try to sell the house...so, get a pressure balanced valve at the minimum. If you really want two handles, then you may need to go with a thermostatic valve. Delta has one in pressure balance, I think.
    Oct 2007
    Scranton Pa.
    Hi Jim, Thanks for the advice. I think I bumped into you on the JB forum also.
    Joe T
    Default Shark bites
    Redwood, Just out of curiousity, why would you recommend shark bite fittings to someone who is perfectly capable of soldering? Shark bite fittings are meant as repair applications just like furncos.
