Originally Posted by
Gary Slusser
When you had the pump out, was there anything blocking the little hole in the inlet screen? If so that will cause slow flow and if blocked enough, no water. The casing screening could be blocked up and if you pumped the well down far enough, the motor's thermal overload may have opened shutting off the pump so it didn't burn up but, how did you get water after it had quit? You say you went out to the well and water was spraying around, that shouldn't have caused NO water, just a low flow volume.
You could have something like rust blocking the 1000' line, so how must rust was on the pump and drop pipe when you pulled it?
The well could be 'going dry' and you are pumping form deeper in the well, that can cause low flow. There could be something wrong in the wet end slowing it down or excessive heat may have damaged impellors etc.. What brand and model pump is it?
