Stuck tub trap
philliplederer
The cap for my tub trap is stuck. I expect the plumbing is 1940's. As you can see from the picture the cap for the trap is about 3 inches across with a hex head that is about 7/8 inch. The cap is screwed into the threaded sleeve that rises from the trap.
The cap is stuck. My room for manoeuver is small. The photo is shot from a service door about 1.5 feet wide. I have tried a breaker bar with a proper socket but so far I have not been able to budge the cap.
Can you advise me on a smart way to remove the cap? I think the cap is brass. I was thinking about heating the sleeve with a torch hoping that the expansion of the sleeve will loosen up the joint. But I am a bit apprehensive in using a torch in such tight quarters.
Thanks in advance for any help you can offer
TedL
NY Capital District
First, buy a replacement cap.
Second, make sure the drum is supported underneath. Use shims if necessary.
Third, whack the raised center of the plug with a hammer (3-5 lb mallet is better) a few times. It should then unscrew more readily.
If not, brass can be readily cut with a cold chisel, dremel, drill, or combination of them.
philliplederer
replacement cap
Are these caps standard? Besides the diameter, what other spec do I need to specify one.
P
TedL
NY Capital District
If it's a standard 3 inch brass cleanout plug, you can get it at any hardware store with a decent plumbing section, or a big box home center. Looks like it, but hard to tell for sure from here. Most will have a square raised or recessed, or long oval recess, for turning. Drum traps often have a cover, rather than a plug, though.
Check this:
http://plumbing.hardwarestore.com/52-337-cleanout-plugs.aspx
Redwood
That looks like someone may have put a rgular cleanout plug on a drum trap...
Usually a miss match of threads...:eek:
philliplederer
thanks for the observation but how to proceed?
I put some penetrating oil on the top to help loosen the threads. That is the wet stuff you see in the picture. Also a guy at Home Depot suggested heating the trap cover with a torch and then dowsing with cold water to free up the threads.
But your observation suggests a bigger problem.
How can I tell if the threads are mismatched?
If they are how could I clean out the trap?
Phil
TedL
NY Capital District
You have to remove the cover to clean out the trap. It may invove cutting/breaking the current plug. Get the replacement cover/plug first.
If the trap is cast iron/steel, it should have won any thread mismatch battle with a brass plug. The brass should have yielded. A cover, like in the link above, would be the correct replacement. If the threads on the drum are rust damaged, that could be why someone used a plug, but most likely thay just used what was easier to find.
You're not going to know 'til you get that one off.
You're working in a confined, limited access area. You've sprayed a flammable liquid. Now, you seem prepared to put a torch to it. Rather than a hammer. Is there something wrong with this picture?
trap
It is a brass trap. Either manufactured that way or assembled from pieces. The plug should be a standard raised head brass plug. It looks like 2" but without a way to compare it, it could be larger. Unless you get rid of the liquid completely, DO NOT use a torch to heat it or you will have a fire on your hands. An extension to the breaker bar should extract it, assuming you have the correct sized socket, or an impact wrench if there is enough space to get it into the opening.
TedL
NY Capital District
That sounds like a 3" nominal size plug. I just measured one in my basement, with the size stamped into it, and it's appx. 3 1/4.
philliplederer
I measured the plug this am. It is actually 2.5 inches.
Of course, I would completely remove the penetrating oil from the cap using detergent before putting a torch on such a thing, (Plus have a fire extinguisher right beside me!).
d
plug
That would make it about a 2" plug because 2 1/2" would be closer to 3". A 2" plug should never be able to defeat a full grown person. Get tough with it.
TedL
NY Capital District
A hex head will take a standard (automotive) socket (1/2 inch drive preferred). With a cheater bar (a length of pipe slipped over the ratchet handle), a kid should be able to break it loose.
philliplederer
Thanks for your ideas
The job is not quite so easy because I have very little room to maneuver--the trap is about 20 inches in the access door which is only about 10 inches wide. The hex nut on the trap is only about 1/4 inch high and my hex wrench flexes and slips off the nut as I cannot put any weight down to keep the socket in place
What I am going to do is to get the pipe you suggest to fit over my 1/2 inch drive handle to act as a lever. Also I will mount a board cross wise from the 2x4 you see in the picture to the remains of a plank floor you see on the left hand side of the picture. I will drill a hole in the board right above the trap to accept a drive extension so I can hold the socket perfectly perpendicular to the nut, so it won't slip. This seems necessary since I need to manage the lever (the pipe) at the same time as I must keep the socket from falling off.
By the way, what you see in this crawl space is the debris of a former bedroom converted to a bath in a house build in 1835. Needless to say I am not the one who put in the bathroom which I guess hails from about 1940.
Any advice or alternative recommendations would be valued.
Thanks again,
Phil
Jay Mpls
Master plumber
Minneapolis
Have you considered opening the wall a bit more and cutting out the drum trap and putting in a regular P trap.
philliplederer
For the record: You guys are geniuses
It has been a while since my last posting on this topic . I must report that wacking the cap a couple of times loosened it.
I was surprised by how thin the brass cap was. But despite its distortion, it screwed on and off quite easily.
Phil
