Results 1 to 4 of 4
Thread: Adding Circuits using ROMEX® vs. AC cable
    Default Adding Circuits using ROMEX® vs. AC cable
    My house was built using AC cable (w/bonding strip). I am now refinishing my basement and would like to add circuits from the fuse box using ROMEX®/NM....I have found working w/ROMEX® to be much easier/cheaper. Is this allowed code wise? If so how do I ground the ROMEX®/NM in the fuse box?
    Sorry for the repost.
    Extreme DIY Homeowner Scuba_Dave's Avatar
    Jan 2009
    South of Boston, MA
    Where are you located?
    Codes vary by area
    DIY Handyman (not 4 hire)
    I have enough to do to my own house
    tx for the reply..... I am in New Jersey..
    Licensed Electrical Contractor Speedy Petey's Avatar
    Jun 2007
    NY State, USA
    NM cable should be fine unless you are in some big city. Even NYC relaxed it's "no NM" rule.
    In the main panel the grounds go on the same bar as the neutrals. Do not connect both ground and neutral in the same hole.
    Answers based on the 2008 & 2011 NEC. If you're on the '14 already I feel sorry for you.
  1. ROMEX®/cable color changes
    By taz110 in forum Electrical Forum discussion & Blog
    Last Post: 09-08-2013, 10:28 AM
  2. 15 amp and 20 amp circuits in same box
    By LHO in forum Electrical Forum discussion & Blog
    Last Post: 10-26-2011, 08:23 AM
  3. two circuits in one box?
    By tregg in forum Electrical Forum discussion & Blog
    Last Post: 07-13-2010, 06:18 PM
  4. Cable Drain (long cable needed)
    By dick2222 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-11-2009, 07:03 PM
  5. New Kitchen Circuits Using 12-3
    By DrummerDad in forum Electrical Forum discussion & Blog
    Last Post: 07-25-2007, 10:38 PM
