Page 1 of 2 12 LastLast
Results 1 to 15 of 29
Thread: Main Disconnect Question
    Default Main Disconnect Question
    What are the requirements for a main disconnect on 200 amp service?
    Is a disconnect required at the meter or will a 200 amp panel with a disconnect be correct? The panel box is not located on an interior wall right behind the meter, it is at least 20 ft away from the meter. The main wire going to the panel would always be hot with no way to turn if off without calling the power company or pulling the meter.
    Thanks for any input.
    Licensed Electrical Contractor Speedy Petey's Avatar
    Jun 2007
    NY State, USA
    I hate to seem like a jerk, but you are the building inspector. What do your local codes say?
    According to the NEC you would need a disconnect "installed at a readily accessible location either outside of a building or structure or inside nearest the point of entrance of the service conductors."
    Jun 2007
    North Carolina
    Quote Originally Posted by Speedy Petey View Post
    Petey
    Ever seen a "building inspector" that had enough sense to get in out of the rain?
    Code Enforcement codeone's Avatar
    Sep 2008
    North Carolina
    Quote Originally Posted by jwelectric View Post
    Petey
    Mike , you know we will turn you down anytime! Rain or Shine. And enjoy it! Mel
    Jun 2007
    North Carolina
    Quote Originally Posted by codeone View Post
    See here is one that admitts he will stay out in the rain even if it is just to turn someone down.
    Mel We all know that the inspectors are like the mail carriers. Neither rain or snow will keep an inspector from doing his job.
    Default My response.
    If my name was Obama I guess you would think I was the President of the United States?
    Extreme DIY Homeowner Scuba_Dave's Avatar
    Jan 2009
    South of Boston, MA
    In MA the main wires going to the panel are always hot unless the meter is pulled
    Are you the President?
    DIY Handyman (not 4 hire)
    I have enough to do to my own house
    Jun 2007
    NY State, USA
    Quote Originally Posted by jaxbldginspector View Post
    I have absolutely NO idea what this means.
    Sep 2008
    North Carolina
    Maybe Imposter? Fraud? ETC?
    Jun 2007
    NY State, USA
    Oh. DUH!!!!!!!!!
    No jax, but if you come on a home improvement message board with a name like yours why would we have reason to think anything else???
    Default disconnect
    Here, there MUST be a main disconnect at the meter so the power company can disconnect the house if they wish to avoid power surges into the building. IT can be a simple disconnect, or the house panel with a main disconnect, but must be able to disable the entire building.
    It's stupid and IMO dangerous but NEC allows it.
    Like HJ says, you can't do it in AZ. In some places you can just run exposed cable tacked to the side of the building.
    Jan 2009
    South of Boston, MA
    Would that disconnect be the meter itself?
    Or inside the meter base?
    Our Main panel is in the basement
    The meter is directly outside - up about 16" on the outside wall
    Jun 2007
    NY State, USA
    Quote Originally Posted by 220/221 View Post
    Why would you say this?
    Very few areas require an outside shutoff. Because you are one of them you think it is stupid not to have it.
    That is like saying Chicago is right for requiring all conduit in a residence and the rest of the country is stupid.
    IMO means "In my opinion"......right?
    I can offer an explanation but it's not really up for debate because it is simply my opinion.
    I have seen numerous fires on cable WITH protection, especially higher amperage protection like water heater/range and AC cable. A fault on an unfused/protected cable would certainly be likely to cause a fire.
    Things are always happening to cables in peoples houses. How many sawsalled cables have you repaired/replaced? Houses are constantly being renovated and often by the homeowners themselves. I think it is only prudent to provide overcurrent protection on any cable run inside a house or within reach of people in normal circunstances.
    A lot of places in the world have seriously substandard electrical systems, You look at the pics from India and think "That is stupid" not because you live in a place with a reasonably safe system but because you know and have seen the dangers involved.
    Chicago?
    It is my opinion that conduit and wire systems are more safe than NM systems but I do think NM systems are safe enough.
