New Water Heater Problem
jti67
I recently installed a new electric water heater in our house, a 50 gallon Whirlpool. The problem is the water is plenty hot but there doesnt seem to be the same pressure or flow rate of hot water at the shower head, the mixing valve has to be closer to the hot side then with the previous heater and we have to tweak the control during the shower to keep it comfortable.
We are on a well and our old heater was 18 years old. I would appreciate any help.
heater
"Plenty hot" and "as hot as the old heater" may not be the same. If your thermostat is set lower than the previous one, then the way you operate the shower valve will be different also.
jti67
Yes, it was an energy smart talked to few people said they had no problems with thiers. I have tried diffrent water temp still have same problem.
Thanks for the replies wish I would of found this site before installing new heater.
