I have an exterior crock for my sump pump. I have lived in this house for 3 years and have had it flood my basement 6 times. After replacing the pump and still having problems, I want to point out some basic facts and see if anyone can tell me what is wrong with the system. The home has previously had basement waterproofing done as is evidenced by the curb around the interior walls of the basement. I can find little or no evidence of seepage through the walls, all water appears to come up through the floor drain. From the floor drain, following the pipe straight out of the house, 3 foot from the foundation, is the crock with the operating sump pump. The pump cycles every 5 minutes for about 20 or 30 seconds and pumps all the water out of the crock. The problem is that the crock does not refill as fast as the water is brought to it, and the excess is stored in my basement. We have had a midwinter thaw here in Michigan and there is an abundance of water. I have shoved a water hose down the floor drain with a sprayer attachment to attempt to ream out potential debris from the line, but I could not make the hose appear in the crock. Why not?
Why doesn't the crock fill immediately and pump the entire basement before shutting off? Should i install a new crock inside my basement for a better system?
Any advice is appreciated.
