Thread: threaded fittings
    Default threaded fittings
    Hello '
    Here's a problem thats been vexing us for a couple years.installed new pressure tank threaded fittings become loose after awhile how can this happen?
    Apr 2005
    Vibration is most likely the reason. What type of fittings? Material?
    DIY Senior Member captwally's Avatar
    Apr 2005
    Florida
    Yes, sounds like vibration, and as rugged asked, what materials are involved? Most likely the pressure tank is steel with a female threaded fitting to connect to the plumbing system.
    This time when you re-plumb the tank, make sure all fittings and threads are dry, use a quality pipe thread compound and allow it to fully cure prior to pressurizing the system.
    Measure Twice, Cut Once
    Wally
