Originally Posted by
Porky
Run a PVC pipe to near the bottom and connect it to a 125 to 160cfm portable air compressor ........Once it starts blowing it will blow everything out of the well. . . rocks, bugs, frogs, snakes and whatever!
Once the well is reasonably clean you can check the well for flow.......
Then you can decide what size pump the well can handle..........
mix Bleach with water and pour it in the well, ........
then have the water tested...........
If the water comes back as safe you're good to go.
