Results 1 to 8 of 8
Thread: circulator
    DIY Junior Member
    Jan 2009
    long island
    Default circulator
    Baseboard oil fired hydronic two zone heat. I have a noisy circulator that I guess needs to be replaced. My problem is I can not deciper what kind of circulators I have. They are twenty plus years old and are 5" from flange to flange. There is two allen cap screws diagnally holding the motor on to the pump housing. The only circulators I can locate are 61/2" face to face. Any suggestions? Thanks in advance.
    Master Plumber nhmaster's Avatar
    Jul 2008
    S. Maine
    Guessing it's an older Grundfos but without a picture can't tell. I can tell you with 100% certainty though that if you get me a picture of it I will geive you the answer.
    DIY Junior Member
    Jan 2009
    long island
    Default circulator
    How do I attach a picture to reply? Thanks again.
    When you have the reply window open, scroll down to an entry called 'manage attachments'. You'll have to scale the resolution down to get the image size within allowances. If you just crop it, it might be too small to see anything worthwhile.
    DIY Junior Member
    Jan 2009
    long island
    Default circulator
Size:  54.3 KB OK here it goes. The housing is 5" from face of flange to face of flange. Thanks again.
    DIY Junior Member
    Jan 2009
    long island
    Default circulator
    Another view
    DIY Junior Member
    Jan 2009
    long island
    Default circulator
    Any suggestions, anyone?
    Computer Programmer Bill Arden's Avatar
    Sep 2006
    MN, USA
    The problem here is that we don't have enough information.
    changing the pipe length is the easy part.
    Making sure the new pump can create the needed flow rate and pressure is a bit more tricky.
    Important note – I don’t know man made laws, just laws of physics
    Disclaimer: I'm a big fan of Darwin awards.
