Results 1 to 8 of 8
Thread: 36" x 48" shower base
    DIY Member FlynHokie's Avatar
    Jan 2009
    Williamsburg, VA
    Default 36" x 48" shower base
    I'm having a hard time finding a 36" by 48" shower base. Is that an abnormal size? Our old fiberglass one piece shower stall measured that. I want to replace it with a solid surface shower base and tile the walls, but I can't find any solid surface ones that measure that.
    Any recommendations?
    There are places that will make a custom one, but it isn't really all that bad to make your own and tile it. Check out www.johnbridge.com for some ideas and help with tiling, whether you decide to make it or not. I'd also visit www.schluter.com and review Kerdi...neat stuff. While harder to find, Wedi has a tileable system that might work for you as well.
    I teach guitar:You call that a job? Howard Emerson's Avatar
    Apr 2008
    Huntington Station, NY
    Quote Originally Posted by FlynHokie View Post
    What color?
    http://americh.com/single_product.ph...werbases&id=26
    They make a great base, but on second thought, this one is 'barrier free', for a wheel chair..........I'll check elsewhere.
    Found it: http://americh.com/single_product.ph...werbases&id=11 Ignore the picture they show, which is obviously square, but it is available in single threshold, solid acrylic, in the size you're wanting.
    Go to Americh.com and then find a local dealer.
    HE
    Jan 2009
    Williamsburg, VA
    Thanks much!!!
    Don't want to tile the floor - I'd rather have a solid surface (mainly for cleaning purposes - don't want to mess with cleaning grout floor down the road...
    Thanks for the advice though!!! and the find!!!
    Apr 2008
    Thanks much!!!
    Hi Flyn,
    Where'd we be without Google?
    By the way, I am assuming that you meant to write '48 x 36' when you wrote the measurements.
    '36 x 48', on the other hand, is not something that is made, and it's entirely different. The first measurement is always the length unless specified differently.
    Best of luck with the renovation!
    HE
    DIY Junior Member turkeyvulture's Avatar
    Feb 2009
    California
    Kohler makes a couple of cast iron ones. Also check with your local cultured marble/cultured onyx manufacturer. Here is Sacramento, the make either one to that size and other sizes also.
    Jan 2009
    Williamsburg, VA
    Default Thanks Howard
    That's probably why I wasn't getting any results!
    Jan 2009
    Williamsburg, VA
    Default Transolid Shower Base
    Does anyone have any experience with Transolid Solid Surface shower bases?
