Solder Copper to Brass?
Rsmith99
Oklahoma
I am installing faucet fixtures on the side of a new tub. The faucet requires a tee connection to be soldered between the hot and cold faucets. I will also need to install threaded connectors on the hot and cold feeds to the faucets. I am going to use braided flex hose with 1/2" connectors.
I was going to use all copper connectors but I just saw an episode of TOH and they were solder brass fittings to a copper line. The brass fittings look like they are made better than copper.
Can I solder Brass fittings to the copper faucet lines? Is there any benefit? Any tips on solder all the connections? I have not done this before, but I have watched several videos on soldering copper pipe.
Ron OKC
Gary Swart
Yakima, WA
nhmaster's short answer is correct of course, but there are a couple of things I'd tag on. You need to have a pretty good handle on the techniques of sweating before firing up the torch. The interior of the fitting and exterior of the pipe must be sanded clean and shiny immediately before assembly. There must be a liberal application of flux to the joint. Sweating is accomplished by heating the entire joint to the point that solder will flow when it is applied to the hot joint surface. Since brass requires more heat than copper, you need to be sure the brass is hot enough, but not overheated to the point the flux is burned off. Do not move the soldered joint while it is still hot and don't force cool it with water. After a few seconds, you can wipe the joint with a damp rag to clean up the mess. These techniques won't suddenly transform you into a master plumber, but you should be able to turn out a workable joint albeit butt ugly.:D
fittings
There are few, if any, advantages to using a brass fitting if there is copper one just like it. Some fittings are only made in brass so with them there is no option. Looks have nothing to do with reliability. A brass fitting can have a casting flaw which will not be noticed until the water is turned on, and or even months after the water is turned on if something is temporarily plugging the hole.
Rsmith99
Oklahoma
Successful attempt a sweating copper
Well I can't believe it! I soldered all the copper fittings (about 9 joints I believe) and I didn't have one leak!
Thanks for all the help! Here is a picture....
99k
Radon Contractor and Water Treatment
Fairfield Co.,Connecticut
www.78radon.com
Ron OKC
Brass is an alloy made mostly from copper and zinc. Quite often lead is added too (up to 1% - yes still amazing with all the hazards of lead that code allows this). In addition, aggressive water eats zinc ... just look at the zurn lawsuit that has about 30% zinc and they are falling apart. In closing, I always will pick copper over brass ... but many times you just don't have any choice. Nice job soldering!
