Joe Brok
- Messages
- 12
- Reaction score
- 0
- Points
- 0
One of the most critical elements of an efficient flush is something that we can't see , which is sufficient ventilation and drainage.
It's simple physics, like using your finger to create a vacuum on the end of a straw full of water to keep the water from running out..
Toilets work the same way, if air can't get in , then the water can't get out People are then also surprised to find out that in most cases ventilation is not a constant but rather a constant variable.
I had a client in an apartment building tell me that his toilet works better in the morning than in the afternoon. Logic tells you that as there is more demand on the system there is less ventilation available to each individual fixture which will affect it's performance.
After installing two identical new toilets in the same house I found that one performed much better than the other. The only variable was the location. When you flush them back to back you can actualy hear the difference in the amount of air coming into the fixture that works better. We've all seen the toilets that fill the bowl almost to the top with slowly swirling water and needs a massive amount of water before it flushes .Next time notice how quiet it is when it does that.You can actualy hear that there's hardly any air getting to the fixture.
I've converted close to 400 toilets to dual flush in the past two years and the performance is all over the map.Although toilets that are up-stairs generally work better than those in basements.( There's more gravity up there ) I've had some very old American Standard toilets out-perform newer toilets just because they have better drainage and ventilation.
Bottom line is, you can't allways blame the toilet for poor performance. There a lot going on behind walls and under floors that you can't see that also affects the end result.
