Results 1 to 5 of 5
Thread: PVC Pipe Size for Shower Drain?
    DIY Member gplumb's Avatar
    Feb 2007
    North Carolina
    Default PVC Pipe Size for Shower Drain?
    My house was built in 2003 in Winston-Salem, NC with the plumbing roughed in for a basement bathroom. The PVC pipe for the shower drain is 1 1/2" diameter. I was told by one plumber that it requires a 2" pipe but this is the pipe that was originally installed when the house was inspected at the time. Now I don't want to dig up the concrete floor to replace it if I don't have to. I know codes vary by jurisdiction and may have changed but before I call the permits office here can someone tell me if this might be true i.e., is this a requirement anywhere you know of?
    Default drain
    I do not know of any time when a 1 1/2" drain would have been approved for a shower. The inspector might have been told it was for a bathtub. But in any case, why would you want to spend money finishing that room and then wind up with a shower that does not drain properly, and becomes obstructed quite often? Not to mention possible problems snaking a line that size.
    Feb 2007
    North Carolina
    I looked at the drawing and it shows a tub/shower. Would a 1 1/2" pipe meet the code for that? I understand that a 2" would be better.
    Yes, 1-1/2" is large enough for a tub-shower. That is because the tub offers an emergency reservoir in case of a clog. It's that shortcoming that a shower only does not offer.
    Default drain
    If your code does not specify a minimum 2" pipe for ANY underground drains, then 1 1/2" will pass.
