Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: continuous "relief" from t&p valve
  1. #16
    DIY Junior Member
    Feb 2009
    Sevierville, TN
    i believe all is good (knock on wood). No leaks from the T&P since replacing it yesteray around noon. I want to thank everyone for your help. You saved me bunch of money because I would have just went out and bought a new w/h which would have been 700-800. Thanks again. Next task is replacing the timer on the dishwasher. Everything happens at once.....
    Scott
    T&P Valve looking at two sides.
  2. #17
    Plumber Cass's Avatar
    Nov 2005
    Even though it seems like you do not have a closed system you need to check your water pressure...unless you do you may be shortening the expected life of the heater...buy a pressure gage and check the pressure...I doubt you know what the incoming water pressure is...
  3. #18
    DIY Junior Member
    Feb 2009
    Sevierville, TN
    i planned on doing that today...getting ready to head out and pick up a pressure gage and test it out.
  4. #19
    Default heater
    quote; You saved me bunch of money because I would have just went out and bought a new w/h which would have been 700-800.
    Which is EXACTLY why I tell people to find out WHAT the problem is before doing anything. You had already changed a perfectly good thermostat, which the company paid for, without curing the problem.
