Results 1 to 5 of 5
Thread: Cadet3 elongated toilet, holes from tank to bowl
    Default Cadet3 elongated toilet, holes from tank to bowl
    Can anyone tell me why this toilet has the holes on the left side only, were the water flows down from the tank and into the bowl? I've seen other models were the holes go all around the rim.
    Plumber krow's Avatar
    Feb 2008
    Ontario, Canada
    either the other holes are plugged, or its a manufacture default.
    It should have holes all the way around
    Dec 2007
    Maybe Manuel the Hole Puncher took a Siesta...
    Thanks Guys
    Under the rim of the bowl it feels smooth on the right side, so I don't think they are clogged. I'm still not sure if it's designed that way or if it's a defect.
    Default bowl
    It may be designed that way to create the flushing vortex.
