The two outputs from the thermostat are ran to a relay someplace that is then controlled by the outdoor temperature.
Normally you would leave it in "heat" and the heat pump would run until it got cold and then it would switch modes to use the electric heat when it get's cold.
Edit: One thought would be to look at the wires at the back of the thermostat since the label there is likely to be still readable.
You might also be able to find the relay that switches modes in the unit.
