Thread: Delta Shower Faucet
    DIY Junior Member chas22's Avatar
    Dec 2006
    Oklahoma
    Default Delta Shower Faucet
    I have a Delta shower faucet that was installed about 1 yr. ago. It's a single lever with a temp lever in the center. The large handle as well as the small are getting a little stiff to turn. Can someone tell me if the valve needs to be taken apart and lubed or have I got something to tight. HVAC is my trade and I'm not much of a plumber.
    Not an expert, but I have a similar shower valve. There is nothing to lube, so my thought would be to disassemble it and see if there is something binding. You should be able to get the installation instructions on line.
    Apr 2005
    This is a common problem with the 1700 series Delta.
    I can't remember if it is the cartridge or the handle assembly that causes this.
    Anyone got an answer...Pete? Jerry? Wilma? Fred?
    Romito? Shania?
    Default Delta
    Call Delta customer service and they will either send you a new cartridge or seals for yours.
