Results 1 to 7 of 7
Thread: low voltage wiring?
    Remodel Contractor GabeS's Avatar
    Jan 2007
    Brooklyn NY
    Default low voltage wiring?
    Do you need an electrical license to work with low voltage wiring? ex.) telephone, cable, computer, alarm system, speaker system, etc.
    I heard no from a union electrician. Is that true?
    Also, do you typically need to get permits to run these lines in a preexisting house?
    Gabe
    Don't follow my advice, I only know a thing or two about a thing or two.
    DIY Junior Member Igor's Avatar
    Dec 2007
    Oregon
    It depends on where you are. Many states do require licensing for low-voltage work; some don't.
    Jan 2007
    Brooklyn NY
    I'm in nyc.
    Gabe
    Dec 2006
    Technically? Yes. Ever since 2001 when we adopted the NEC. But it doesn't have to be a regular electrician, there's a separate license for low-voltage wiring.
    But I think it only applies to people doing it for hire; you might be okay DIYing for yourself, I'm not sure. Call the DoB and ask.
    Master Plumber Mark:
    do not hit your thumb...
    __________________
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    I think there is zero likelihood of dying with less than 47v and less than 18 mA. The NEC seems to relax with less than 30vrms, less than 42v peak and less than 60 vdc.
    The phone line delivers about 56vdc at a max. current of ~170mAdc, but the ringing signal is a bit more than 90vrms.
    I doubt it ever killed anyone.
    Well, if you weren't expecting it, the ring voltage might make you fall off a ladder. I know it creates a big surprise if you're holding it when it happens.
    Aug 2008
    MD
    Turns out falling or jumping off a 2' ladder dumps as much energy into your body as several bullets. With knees locked, the power dumped into you is very high because the deceleration is very high.
    The Darwin Awards are always lookin' for people!
