Results 1 to 10 of 10
Thread: Another 4-Inch versus 8-Inch Sink Drill Question
    DIY Junior Member RonnyK's Avatar
    Jan 2009
    Pennsylvania
    Default Another 4-Inch versus 8-Inch Sink Drill Question
    Hi,
    We are replacing the sink in our very small powder room with a pedestal style where the lav measures 24" x 19". Can someone provide some guidance on whether to go with 4-inch or 8-inch centers on the sink drilling?
    Does the 8" refer to the distance between each drilled hole (i.e. the hot tap to the spout is 8" and then another 8" to the cold tap) or is that the measurement between the water taps? Would 8" look out of place in such a small sink and bathroom? Any links to pictures showing the difference would be much appreciated, as well.
    Default faucet
    It is strictly a personal opinion and partly depends on the actual faucet you like the looks of best.
    Jan 2009
    Pennsylvania
    Thanks for the reply. I understand that the choice is up to me when I order the sink, but I was curious about what exactly the 8" (or 4") measurement is between-- valve to valve or valve to spout.
    Dec 2006
    Quote Originally Posted by RonnyK View Post
    Valve-to-valve. Is that really all you wanted to know? Measuring a few faucets around your house, woulda been quicker than the internet... and google, faster than posting a question on a forum...
    Assuming you wanted to know more than that:
    Kitchen faucets are generally 8". Bathroom faucets are mostly 4".
    If you want a pop-up drain, and the holes are on 8" centers, your options will be very limited. It happened to me once, with an antique sink the client wanted to use. Eventually we found a faucet that came as 3 separate assemblies, connected with flex hoses, so it could can fit any measurement, but it took some looking, and there weren't that many styles with that feature.
    If you want the opposite, a 4" center faucet without a pop-up, bar sink faucets are also 4" center.
    Master Plumber Mark:
    do not hit your thumb...
    __________________
    Remodel Contractor GabeS's Avatar
    Jan 2007
    Brooklyn NY
    The measurement is the exact center of hole for the cold water to the exact center of hole for the hot water.
    These holes should already be predrilled if you are buying a vanity set. If it's custom stone the fabricator does it. If you drilling your own holes(I've never actually drilled my own for vanity, only for widespread faucets on jacuzzi's) make a template. Maybe you could even buy a template. I've never looked but I'm sure they are out there.
    Gabe
    Don't follow my advice, I only know a thing or two about a thing or two.
    Jan 2009
    Pennsylvania
    Thanks for the replies. I did look on Google and various websites for pictures and explanations, but the basis for the measurement was not clear to me. My current fixtures are all one-hole.
    Frenchie-- I am not sure where you are coming from when you talk about limited choices for pop up drains in widespread fixtures. I have found an abundance of widespread faucets that have pop-up drains.
    Plumber jimbo's Avatar
    Often, the scale of the sink will "dictate" the choice.....a small sink would look "weird" with a widespread. But in the end, there are multiple choices, and the final choice is yours.
    If you like the spread look, and are working with a smaller scale, Moen has a "mini-spread" which smaller in scale, and has the 3 piece look, but installs on 4" centers.
    Jan 2007
    Brooklyn NY
    center of first circle to the center of the other. It's straightfoward.
    Gabe
    Plumbing Contractor C NUMB's Avatar
    Jan 2009
    NPR, FL
    or you can do this if there is not enough room between the sink and cabinet base for an 8"cc, not exactly what I would prefer but homeowner loves it and in the end thats all that matters
    Single hole faucet applications give a much cleaner look as far as I'm concerned.
    4" centerset= 3 holes
    I-2"-I-2"-I
    8" centerset=3 holes
    I--4"--I--4"--I
    Hope this helps, btw standard hole drilling is 1 3/8"
    I'd Rather Be FISHIN'
    Dec 2006
    3rd hit on google:
    http://www.**************.com/faucetindex.html
    edit: never mind the link (Terry's censorware is blocking it). See attached picture.
    Cheap ones? It was maybe 10 years ago (pre-internet, for me)... all I could find was $250 and up.
    __________________
