Hi,
Sounds like you have very high iron (so do I BTW). Water softeners will handle up to about 4ppm iron. Anything beyond that you will need an iron filter before the softener. "
Yes, I forgot to mention that -- we do have one. It is highly inadequate as well, though we change it out all the time.
However you need to provide us with a professional water test before anyone here can really recommending anything. These tests tell you how much iron, how much hardness, ph, etc. Someone in your area does water testing. Get a test kit from them, follow the instructions for obtaining a sample and return it to them. Make sure to bypass all filters, softeners, etc and let the water run for a few minutes before taking a sample.
This is a good idea -- we had the water tested awhile ago, but it was only after the filter process, to be sure it was drinkable.
Also what is the GPM yeild of your well and knowing what the cut in and cut out settings are on your pressure switch would also help.
I'll look into that.
We just recently had this guy, who was trying to sell us the Triple O, btw, who insisted that our bladder had failed (we assume it had, because we could not get any water, the pressure was gone). He charged us $500 to fix it. Anyway, he swore it was all as it should be, and reset everything as I recall. Again, we need to get more educated about all that, obviously! Sorry, I'm kind of rambling here... I will check with my husband, he most likely knows.
Also what is the purpose of the 2500gal tank? A 2500gal holding tank isn't necessary to remove iron.
The tank is for the Triple O process: instead of the water being pumped up through a bladder at then along the pipe to our filter system at the house, this water is pumped up into a holding tank, which has the filter system - the Triple O, or ozone filtration as I understand - in the tank. The water is filtered there in the tank, and then travels to the house.
http://www.tripleo.com/process.htm
-rick
