Results 1 to 6 of 6
Thread: Green copper pipes
    DIY Member littlebrook's Avatar
    Aug 2008
    Rochester, NY
    Default Green copper pipes
    Hi,
    I was wondering whether I should worry about green patches appearing on my copper pipes, especially around the joints?
    Plumber Cass's Avatar
    The green patches could be nothing or they may be pin holes developing.
    Around the fittings probably nothing between fittings very likely pin holes developing.
    Aug 2008
    Rochester, NY
    what causes pinholes?
    Defective pipe, agressive water, poor elecrical grounding, excessive water flow velocity, excessive use of flux, not cleaning off flux residue...and probably other things as well.
    Aug 2008
    Rochester, NY
    probably bad electrical grounding in my case. When I moved into the house 18 months ago, the ground wire was loosely wrapped around the water meter. Don't know how long it was like that before I put a proper ground clamp on it.
