Results 1 to 6 of 6
Thread: Banded Clamp
    Default Banded Clamp
    I am tapping into my main indoor drain for a basement toilet. And I could use to banded clamps, however my preference would be to use a regular coupler on one side and a rubber on the other but getting the gap to zero is vituallly impossible. How big a gap is allowed when using a 4" banded clamp?
    You normally add 1/4" for the band.
    If the fitting is 9-3/4", you cut out 10"
    Terry Sorry I am a newbie.
    Not sure I follow. I have a 4x4x3 Wye fitting going into this gap and I would like to glue one side in and align the other side as close as possible to the pipe using a clamp, however during my dry fit I cannot get one side in to glue without at least a 1/2 '' gap. Is this too big?
    Questions from readers Guest's Avatar
    posts, emails and comments from readers reposted by Terry
    I don't think you can glue one side and make it work.
    When I"m cutting in a wye, or any fitting for that matter, into a "fixed in place" line, I use two couplings.
    Default connection
    Unless one side or the other is able to be flexed out of the way, there is no way you will install your Y by gluing one side and then a conventional band on the other.
    HJ
    Thx I will do two clamps, However here is a twist. I am reducing from a 4"PVC to a 3"ABS at the WYE and I am less comfortable (after the numerous threads on this forum) about using transition glue. Would a third clamp be okay?
