draven8795
You said the hot and cold water each produce the same amount of flow per minute when you did your test. How many gallons per minute did you get in your test?
Your shower head can clog if you have hard water, so check that also.
Its a brand new shower head so Ive ruled that out. Ill have to do a test with each. Ive only done a gpm test with both turned on and got at least 4 gallons in one minute (I stopped before the minute since I was just testing to see if I could get a water softner that needed 4gpm which I have not purchased yet). I suppose that won't really tell me anything with both on since one could compensate for the other. Ill install the pex tonight and report back any results. Is there a gpm number I should be looking for?
