Results 1 to 4 of 4
Thread: Source for tempering tank
    Vocational Instructor RayP's Avatar
    Jan 2009
    Syracuse NY
    Default Source for tempering tank
    I searched and did not find this addressed. Where can I find a suitable tank for tempering before water heater? Most info I have read uses a gas water heater with the insulatin removed. But there must be a source for a tank for this purpose, right?
    Nov 2008
    Chicago, IL
    Tempering as in making the water warmer before the water reaches the water heater? So basically you are looking for a storage tank to be installed before the water heater if I am understanding what you mean.
    Here is a link to uninsulated tanks http://www.parkerboiler.com/water-ta...rage_tanks.htm and one by Bradford White http://www.bradfordwhite.com/images/...heets/480B.pdf
    Master Plumber nhmaster's Avatar
    Jul 2008
    S. Maine
    You should be able to bick up a galvanized water tank pretty cheap somewhere.
    Jan 2009
    Syracuse NY
    Default Thanks guys!
    Yes, a tank that holds pressure but without insulation. I will check out your suggestions.
