I dont think I would trust anything that Rheem says.
never trust a Techey that teaches theory.....
yes, -30 that is pretty damn cold, but it dont take that to freeze pipes
you had better be installing that unit with some sort of drain pan under it. Something Like a washing maching pan with a drain to the outside...
....just in case those Rheem techs are wrong....
Also, I dont understand how the water lines going to and from this unit in that -30 temp area attic in New Jersey are supposed to keep from freezing and flooding your home either...
are they telling you to run heat tape on all the lines
all the way to the unit???
and if the unit sits without comming on for a whole day
in those harsh conditions, wont that coil get a little frosty??
is their some sort of fail-safe on this ??
Being installed the attic of your home,
I would be very hesitant about this....
I'm not even sure a tank would fit in that closet. What type of vent material would you use to draw air from the attic? PVC? Flexible aluminum vent? Rain gutters? Since this closet sits in an exterior corner directly beneath the entryway to the house, I would have to run 7 pieces of 3" round duct up an exterior wall to provide sufficient air. What would be the consequences of notching my bottom plate to that degree?
