Thread: Connectors for sockets for a Linear T5
    Default Connectors for sockets for a Linear T5
    I am putting together a flourescent light fixture by using linear t5s. I have the sockets but I need neat, sleek connectors. Does anyone know where they can direct me on this?
    Cheers!
    Like an engineer alternety's Avatar
    Apr 2006
    Washington
    Two points to remember.
    You have to have start/run electronics appropriate to the bulbs and voltage.
    The fixtures use the reflector as a ground plane. If there is not a sufficient plane at the right distance, connected to ground; the lamps probably will not work correctly.
