Vortens Vienna 10" toilet
Gramps
Toronto, Ontario
Is the Vortens Vienna a good toilet?
or one I should avoid?
I am looking for a 10" rough in toilet.
3208-3464
Gary Swart
Yakima, WA
This brand is noted in Terry's Report on Low Flow Toilets, but there is no data. However, you might want to look into the Toto Guinevere. This looks to be an excellent choice. Sorry I can't give you any opinions on the Vortens Vienna. I can say this is a brand that I do not recall ever being discussed on this forum, so that makes me a bit skeptical.
We don't even bother selling the Toto Carusoe, though I did use one in my hotel room at Whistler/Blackcomb and it seemed to work fine. The trapway on those is 1-7/8", a bit on the small side.
We sell the Drake, which has a 2-1/8" trapway with long sweeps.
The Cimarron plugged quite a bit when I had it installed in my home.
The Mansfield Alto in my daughters home, they plugged all three the first day they moved into their new home.
The Kohler Wellworth is a common builder grade toilet that gets replaced.
It's nice that the Vortens could flush balls. I've seen many toilets that can, but have problems with paper and other objects.
Many trapways will bounce a ball down the trapway, and catch paper.
And that's why I prefer to use the bowl in the home before writing about it. It's the only real way to test them. Nobody flushes balls away.
I did have the Vortens pressure assist installed for a while with the Flushmate 1.1 gallon flush. The cartridge had a hard time sealing, so I would turn it off between uses. It was bad out of the box.
It's too bad they didn't test any good toilets.
Neotonic
Southern California or Russia
We don't even bother selling the Toto Carosoe, though I did use one in my hotel room at Whistler/Blackcomb and it seemed to work fine. The trapway on those is 1-7/8", a bit on the small side.
And that's why I prefer to use the bowl in the home, it's real.
yeah, I just thought about the Toilet paper situation.. They should have put the Toto Drake in the line up =P Its amazing what you can find on YouTube lol
DaPlumma
Houston Texas
Western commodes
one commode that you don't hear about and is a great flushing commode is the" WESTERN" BRAND COMMODE. I'm a 19yr long plumber that does residential repairs and have replaced many commodes with the "Western" . Customers are always pleased with them and always call for the other commode in the home to be changed out after seeing that it does perform great.
Take a close look at the trapway molded into the porcelain, especially at the point where it turns and goes down the flange to the drain...it looks like it makes a very sharp bend there. Hard to tell for sure. Sharp bends slow things down, and that can cause clogs, especially if you flush a real log!
RedHouse
New York, NY
Will the Vortens Hurricane do better?
Vortens' own words:
2-1/8" Fully Glazed Trapway
High-Eff iciency Toilet (HET) with
Powerful 1.28 gpf / 4.8 lpf Flush
Powered by the 3" HydroSurgeTM
Flushing System
Flushes 1,000 grams of solids per
MaP test
8" x 7" Water Surface
Extra-Large Footprint
Ideal HeightTM A.D.A. Compliant –
1 6-1/2" High
Lifetime Warranty on
Vitreous China
High-Gloss Vitreous China –
Durable, Nonporous
The MAP test flushes plastic wrapped paste...not the same thing as the 'real' stuff, so getting a huge value is easy, plus the smooth plastic wrapped stuff doesn't catch on sharp edges or get slowed down like the real stuff, either. So, hard to say whether this is better or not.
RedHouse
New York, NY
I still think the Vortens is okay. I mean, it isn't a builder grade product, but it's not a commercial grade one either. Toto now makes a 10" Drake which is the best idea.
Gilbert Plumbing
Mesa, Az
Vortens toilets
Thank you for the kind comments about our video.
In our 40+ years of residential plumbing in Arizona, we have been pleased with the performance of the Vorten water closet, installing the Vienna model for the last 6+ years in residential and commercial applications. We have installed thousands of these toilets and our call back for service is close to zero. This, of course, does not include various objects that were never meant to be flushed (such as toilet paper holders or small toys).
Having used many makes and models of water closets in the construction of over 32,000 new homes, the Vortens water closet has had the fewest customer service issues.
