which cast iron pipe should i connect new pvc to for sink and toilet
gaw11365
hi
i'm renovating my bathroom and will be moving my sink and toilet . I have several questions about the new waste plan.
First, I plan on cutting the 4 inch cast iron pipe #5 before the toilet flange and connecting it with a mission clamp to 4 inch pvc so i can move it 4 feet to the right of the picture on the other side of the bathroom . Is that ok to do?
Second question:
I would like to attach the sink waste to the pre existing cast iron pipe on the floor but am not sure if i can connect it to location # 1 or #2 in the picture. If i use another mission clamp for this connection , what do i do with the drain and bivent already present which is not being used # 3. Is that ok?
Third question
I plan on cutting the pipe on the floor to the left of the #5 but do I have to cap that if not being used. If so , how do I cap the cast iron .
I am assuming that I don't need an extra dry vent for the fixtures since they are all so close to the main stack.
thank you
gw
drains
If you do it correctly, and that means using the RIGHT Mission clamp.
Second question:
IF you have to ask, maybe you shouldn't be doing this. And it makes no difference WHERE, or HOW CLOSE and existing vent is to the connection, unless the vent is installed properly for THAT connection it is useless.
Third question
If you do not cap it, you will flood the downstairs when any water is used in the drain line. You use a No-Hub cast iron plug.
gaw11365
thank you for your response. I understand your answers to #1 and #3 but wasn't sure about answer #2. I don't think I would need to add a vent to a sink that was so close to the main stack so I assume I have to plug it also ?
thank you
gary w
