Thread: small space new toilet
    Default small space new toilet
    we live at the beach so scale is a problem in the current old toilet. The bathroom is next to the bedroom and do not want to hear the toilet running. We are two adults but want the most pressure as our water pressure is not the best but not all that bad. We have an old toilet and are worried about the low flow. I am looking at the toto drake and ultramax. any help would be great.
    On a gravity flush toilet, the incoming water pressure doesn't make any diference in the flushing performance, it will only slow the refill. A pressure assist toilet might be affected if your incoming presure is really low. Don't confuse pressure with volume. If you have old galvanized piping, your volume could be poor, but the pressure may be fine. That being said, a pressure assist toilet will typically be a lot louder than a gravity flush. The Drake is a fine toilet...I put two of them in my mother's house. one ADA height and one standard elongated. Probably should have gotten her two ADA height, but the one that gets used most is ADA.
    Just to add a thought to Jim's answer. A low flow toilet will fill about 3xs as fast as the old full flow because it only takes 1.28 to 1.6 gallons (depending on the model you choose) A power assist in addition to being noisy will not provide you with a better flush. Either the Eco Drake or regular Drake will be an excellent choice. I would pitch the ADA height since the use will be by adults.
