Circulation Pump Question
Stevetothink
I have baseboard hotwater heat in an 800 square foot apartment. I believe my circulation pump has failed. I have 2 questions.
1. How much should I expect to pay a professional to repair or replace my existing unit?
2. Ho much should I expect to pay if I were to buy a new pump myself and try to install it?
Thanks in advance.
Steven
Jimbo
San Diego, CA
A complete pump would run $300 to $450 + labor. But there are parts...bearing assembly, shaft seal assembly, impeller, and of course motor, which can be separtely replaced for a lot less. But do you know what is bad?
Stevetothink
I'm not sure exactly what is bad but it is making a faint clicking sound and the hear isn't getting to the entire house evenly. I have a guy coming to check it out today. based upon my description, he thinks he can repair it for about $200. I'm wondering if that's a good deal or if I should just buy a new one and put it in myself.
Steven
NHmaster
S. Maine
200 is a real good price and unless you know what you are doing putting one on is most definatly not a homeowner job.
Stevetothink
Thanks for the info. It turns out that the circulator pump is fine. Some standard maintenance and good bleed job did the trick. I'm happy and warm again.
