likely part of the black rubber rectangular gasket sheared off and is lodged in shower port of valve, you will need a strong o ring pick and maybe a new cartridge to fix, you first need to turn water off to faucet, disassemble faucet, with cartridge removed there will be a port at 12 o clock inside of where the cartridge goes, poke and pry up in the port with a good quality o ring pick to dislodge rubber bits, reassemble faucet and all should be good as long as pressure was good before starting, if not there may be a mineral deposit build up in this area, moen faucets are really nice in that there are few moving parts to go wrong
