Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Drilling concrete slab
  1. #16
    Dec 2006
    Ramsets often don't grab in well-cured concrete, the way they do in fresh.
    Also - he's not a pro - when is he ever gonna need a ramset again? A hammerdrill will get used for other things, inevitably, eventually.
    Master Plumber Mark:
    do not hit your thumb...
    __________________
  2. #17
    Aug 2008
    Fairfield Co.,Connecticut
    Still sounds like a lot of work!
    Can you say Ramset! http://www.ramset.com/721.asp
    I bought one of these on a job last month ... the ramset model I used has the charges in a plastic strip instead of loose. I find these are very consistant going into block but going into cured concrete is a crapshoot. Going into a floor is not that critical and would have worked fine ... then ebey when done.
  3. #18
    Jul 2007
    USA
    I am in Key West at the moment enjoying the sun.
    But I maintain that screws and anchors are the way to do this in the spirit of craftmanship.
    I am approaching a gas pipe that runs the length of one wall across the basement ceiling. It is positioned about 5 inches from the wall which means I have a choice.
    I can either box it in behind the stud wall (which would mean I could not access it) or in front of the wall but cover it behind the suspended ceiling.
    Which is better? I either lose access and a little square footage, or maintain access but lose some ceiling height.
  4. #19
    Remodel Contractor GabeS's Avatar
    Jan 2007
    Brooklyn NY
    Number one, I don't believe you are allowed to bury the pipe behind the stud wall. Second, 5" is a lot of room to waste. Definitely build the wall against the foundation and build a soffit to cover the pipe. Then if you have to make a repair or replace the pipe it's much easier to get to.
    Rerouting the pipe is also an option if it's bothering a lot. More time and money, but you are already investing a lot of time and money to finish the basement. See if there's another path for the pipe.
    Gabe
    Don't follow my advice, I only know a thing or two about a thing or two.
