Results 1 to 3 of 3
Thread: Hot Water Circulating Pump
    Default Hot Water Circulating Pump
    I am considering to have a Hot Water Circulating Pump installed. Can anybody recommend a good brand? I heard that Grundfos is best. Is that true? I visited Home Depot and Lowes and both carry only Watts.
    Electrician Chris75's Avatar
    Aug 2007
    Litchfield, CT
    Quote Originally Posted by SAnsari View Post
    I have the watts one, it works fine... You may not be happy with the cross over connection though, so I recommend a seperate recirc line as a first option.
    Default pump
    If you are referring to a "retro fit" circulation system, the Grundfos and Laing both make good ones.
