Thread: Dark Greenish Well Water w/Black Sediment
    DIY Junior Member
    Jan 2009
    Venice, FL
    Unhappy Dark Greenish Well Water w/Black Sediment
    My well water suddenly started to come out of the faucet a dark greenish color with black sediment. After several flushes and running the bathtub, it appears to be somewhat normal again, although we couldn't be sure it didn't have a slight green tint to it. I'm afraid to use the water now. What caused this? Is it likely to happen again. I don't want to be stuck in the shower with green water! Please help.
    Previous member sammyhydro11's Avatar
    Dec 2006
    Massachusetts
    What type of well do you have? Is the top of it underground in a well pit?
    sammy
    www.tylerwellandpump.com
    Since you're in FL, if you have a clear sump on a water filter that's outside, you could have had a slug of algae break loose from inside the housing or, it could be copper corrosion.
    You need to post info about your well and water system, any water filters etc. and any odors, rust stains etc..
