Page 1 of 4 1234 LastLast
Results 1 to 15 of 54
Thread: Insulating old house
    DIY Senior Member Master Brian's Avatar
    Nov 2008
    Kansas
    Default Insulating old house
    I have a 1915 Craftsman style Bungalow with clapboard siding. I know the walls aren't insulated well/if at all. I am also pretty sure there is no sheeting under the siding, as when I went to drill a hole for a bathroom vent, it was siding then empty wall spac.
    I am going to be doing a paint job this spring on the outside of the house and have a few thoughts....
    I am pretty sure I can pull one or two rows of siding off in a few areas to get access to the inside of the walls and if not, I am thinking I can take my 2" hole saw and just drill holes at every cavity, then replace the plug, fill and sand. The 1st method would be the cleanest and quickest if it works like I think it will, but I know I can do the 2nd method.
    My questions are what type of insulation should I blow into the walls? I still have the lath and plaster and don't want to create any issues with it. I have thought and read about the foam, but think it might be too risky and expensive. At this point, anything is better than the dead air space I have as insulation now.
    My thoughts...without a vapor barrier, you risk rotting the structure if you use something like cellulose. A closed-celled foam might qualify as a vapor barrier - you'd have to check carefully.
    Nov 2008
    Kansas
    Can you explain?
    Nov 2008
    Kansas
    When I ask to explain, maybe I should clarify...
    I understand the vapor barrier keeps moisture and such at bay, but I thought cellulose was good at combating mold. I'm sure the spray foam is out of the question do to cost and the fact, I probably won't/can't do it myself due to lack of tools for that job.
    I guess I hadn't thought of the vapor barrier angle as I've just heard and seen of others doing this often. How do you get around the vapor barrier and/or how do you determine if it's needed?
    Insulation moves your dew point (the point where condensation occurs), and without a vapor barrier, it could end up inside of the wall. Cellulose doesn't allow air movement much if installed properly so that helps, but if the cellulose gets wet from condensation, it will take forever to dry out. It might not mold, but the wood, can.
    There are companies that sell spray foam in large kits in various configurations that are much more ecconomical than little cans and maybe a contractor doing it. It can be a messy job, and you need to be careful not to put in too much, or you can split walls, break windows, bow walls. But if you follow the instructions and pick the proper foam to do it, you shouldn't have problems.
    Dec 2006
    Aside from the vapor-barrier - what about a weather-resitive barrier?
    If there's no sheathing, and you have any leaks in the siding... right now, water gets in but also gets out, and there's possibly enough airflow to dry things out. But if you stuff the cavity with insulation, especially a non-waterproof insulation like cellulose... your house will rot.
    The right foam for this situation is poured, not sprayed, and it's pretty expensive. And if there's no WRB, or if the WRB is degraded, you'll still have moisture coming in via the studs; more to the point, you'll be effectively glueing the siding on, good luck with any repairs later on.
    Sorry, but the only really correct approach, is to pull the siding completely. Insulate, sheath, wrap, and re-side.
    Master Plumber Mark:
    do not hit your thumb...
    __________________
    DIY Junior Member
    Dec 2008
    Norwood OH
    Quote Originally Posted by Master Brian View Post
    Keep in mind there is more than one kind of foam. There are expanding (looks like shaving cream) and non-expanding foams. Within the expanding category, there are open and closed cell varieties.
    If you're worried about blowing the plaster and lathe, you can use the non-expanding variety, e.g.:
    http://retrofoam.com/
    http://www.usainsulation.net/
    Expanding:
    http://www.demilecusa.com/
    http://www.icynene.com/
    http://www.emegabuild.com/
    DIY kits:
    http://www.tigerfoam.com/
    FWIW, I used expanding foam (Demilec) on plaster and lathe in my finished attic, and only had a problem over one window. I figured that plaster would have needed repair anyway, so I'll just put up some blueboard and get it skimmed when the rest of the room is finished.
    I didn't have any problems with the underside of my roof deck blowing out any plaster. An experienced insulation contractor should be able to advise you. I certainly wouldn't discount it before talking to someone who has experience in retrofitting insulation. You may very well be fine.
    Nov 2008
    Kansas
    Frenchie, You are probably correct about the leaks, I had thought about that. I haven't decided what I am doing yet, but I will say, when I paint, there won't be any gaps/cracks anywhere I touch. I plan on using expanding foam spray and 50yr caulking throughout. With that said, I realize there is always the potential for a shift or crack to occur that I miss.
    I don't see any future concerns regarding "glueing" the siding on with an expanding foam, as this is the original clapboard siding and I don't ever plan on replacing it!
    I also checked on a few of the foam products and haven't found any dealers in my area, but I may call them next week and see what they say.
    Tearing the siding off is a thought. I just wonder how much work/trouble it would be furring the windows and such out to account for sheating. Hmm... Siding in and of itself doesn't scare me one bit, as I used to be a siding sub on new construction for a few years. Problem is I've never messed with the clapboard much and I want to keep this original siding.
    Let me ask this, is there some wrap that I could possibly use in place of using sheeting? I know sheeting would be preferred, but.......
    If I pull the siding off, should I just install fiberglass batting? I know the sprays might be more efficient, but I am not easily convinced all of that type of stuff is really worth the added cost. I'm sure not paying someone $10k+/- to insulate my house. The other thing I worry about is getting this house too tight and causing issues. These old houses are designed to breathe.
    Thanks for the things to ponder....
    Dec 2006
    Even if the foam means it starts rotting?
    Google "pour foam".
    Yes, you could then use fiberglass, or cellulose... Would the savings, from not using foam, cover the extra hassle? Not sure.
    As for sheathing - house that old probably has left-in bracing for racking/sheer resistance, so it's not absolutely necessary. Probably ok with just housewrap. It's been there for awhile, right? And it's still fine?
    If you open up the walls & there's no bracing, though... I dunno.
    Mind you, if you don't add sheathing, you'll have to be extra-careful with flashing, because it's one less backup drainage plane. And must tape every seam, because it's also your air-seal, now. FG is useless if there's air movement, it's just a big air filter then.
    You're right that the old walls are designed to breathe - they work by a very different process than modern walls. The old walls let water in, but also let it out again; and they have plenty of airflow (drafts) to make sure things dry out, later. That's why it gets complicated when you insulate them. It's easy to cause a disaster. You stick insulation in there, now there's something that holds water if it gets damp.
    So your water-management details have to be tighter, and you have to seal up the drafts, to prevent moisture-laden air getting in & condensing inside the wall. But by doing that you're also making it harder for any moisture that does get in, to dry out... The worst outcome is when you try to compromise between new & old approaches. An insulated wall that leaks, doesn't last long.
    A lot to think about, for sure.
    __________________
    Nov 2008
    Kansas
    You are correct, there is a lot to think about. The worst part is for every question, there are a dozen different answers!
    No, the foam is not good if it gets wet and the wood rots out. I do think, at least to some extent, that if I at least stay on top of the exterior maintenance, any rotting should be kept to a minimum. It would be one thing, if it sat and sat and sat in damp conditions for years, but, if you can catch the issue, that "should" buy some time. That theory probably works best when dealing with rain and such. The condensation is another thing all together and a real concern, because my windows ice up badly in the really cold weather!
    I have googled pour foam before, but will do it again. I know there are some DIY kits, but they just seem really, really expensive. My average utitlity bill is probably $250-$300, for this 1-1/2 story, 1900 sq ft house with about 700sq ft of unfinished basement. I know that is not good by any stretch compared to today's newer houses, but it is what it is on these old houses. In fact my previous house was 1300sq ft and 1-1/2 story and it cost me about $25 per month more for utilities! My point is, it would take 10+ years to justify spending ~$10k on having someone insulate the house correctly. I just am not certainit's worth that.
    I also know from experience, with watercraft, with two part foams, they do tend to get waterlogged over time. I suppose one solution which wouldn't provide excellent R value, would be to use 2" rigged foam panels, cut to size and inserted into the walls. With that, I would then leave a little "air chamber" as well throughout he outside of the wall, which would allow the wall to still breathe! Thoughts?
    Jan 2009
    South of Boston, MA
    I went thru similar problems with my old house - 1905
    Luckily it had sheathing & tar paper
    The inside was a mess so I gutted room by room on the inside & insulated
    The problem I see with the rigid foam boards are they have to be tight
    If you have any gaps it will let air flow in
    That said any insulation is better then none, but better to do it right the 1st time. My kitchen was cold & drafty before, after it was nice & warm.
    I was heating with wood - open floor plan, so it cut down on the amount of wood I went thru
    Is your basement "warm" ? I had single pane windows & a door that did not shut right. New door, new windows, insulated the sill plate all the way around. Basement went from 45 the 1st year to now around 58-63 depending upon outside temps
    How old are your windows? As purchased our house had vinyl replacement windows, But they never took out the sash weights & insulated the cavities. I spent maybe $4500 on new windows, I have since saved that money in reduced heating costs. An added bonus is the house is much quieter
    DIY Handyman (not 4 hire)
    Nov 2008
    Kansas
    Quote Originally Posted by Scuba_Dave View Post
    There is always a chance, there is something on a different wall, but where I drilled through had nothing. Hmmm....
    If I did the rigid foam, I think I would lightly push the panels against the plaster wall. As long as it isn't tight, it shouldn't hurt the lathe and it would allow some air movement. I would then use gap and crack spray foam to seal the panels to the studs. This would not only keep it in place, but stop drafts. I would also then have about 1" of dead air space between the outside wall and the panel, which should allow sufficient air movement to keep things dry. That is my thoughts in any case, not sure how it would work in the real world. I am not overtly impressed by the R value of the foam. 2" foam seems to be 7.8 R value. I'm sure if I foamed the edges, it would go up and again, it is better than what I have now and shouldn't rot anything out.
    Basement is ok, it gets a little chilly, but there again nothing is insulated. I am going to be going in and sticking something in the cavities along the sill plate. I am also going to most likely insulate the ceiling with at least 3-1/2" fiberglass batting. This is only to stop sound as I will be turning my basement into a game/tv room.
    Windows all appear to be original and I'm not changing them. I currently have some wood storm windows, which I plan on making/installing on all windows and some aluminum storm windows on some. Most windows have nothing on the outside and most probably need re-glazed. I have read through several sites that the old windows, when rebuilt and maintained are just as efficient as current windows, except they have a much longer life span. I will probably eventually get to the sash weights and either rework them, per "This Old House" and insulate them, or remove the weights and use the "Sash Springs", which work similar to a tape measure thus freeing up that cavity to be insulated fully.
    Jan 2009
    South of Boston, MA
    If you are going to seal the rigid boards then that would work
    Just be careful about codes & renovation. I know someone who was renovating a house in a cold climate & the building dept stepped in & said they would have to meet current insulation codes, His intent was to sell the house, so that was the main reason I believe
    I can see wanting to keep the look with a 1915 Craftsman
    My old house was just a cottage that had been partially updated
    My current house has R7 insulation, 3/4 sheathing, & thick old wallboard with a heavy plaster (?) finish. It does very well on heat, but every window I had to custom cut the trim
    The windows & doors made the most improvement in my basement
    But insulating the sill plate also helped - I could feel the cold/cold air
    I went around with a caulking gun & sealed everywhere I felt cold air
    Insulating where the sash weights are was another major improvement
    With the garage addition, sunroom, greenhouse, 3 season front porch, & a new 6" wall in the front I have added additional insulated areas around the old walls of my house. If I ever get "caught up" I will take down the wall board from the inside, remove the R7 on 2 rooms & insulate them with R15. The rest of the house is OK with the additions
    I've learned over the years its better to do things right the 1st time
    In some cases I made Temp fixes until I could do what I wanted
    Nov 2008
    Kansas
    Doing things right the first time is what I want to do as well. The hard part is it normally requires starting 5 other jobs, just to complete the one....
    Nothing worse than later regretting the job. To be honest, if I have to go through the work of pulling off all the siding, I probably won't do anything. A friend of mine is a contractor and he seems to think blowing the cellulose in would be fine as well. Of course, he is used to new houses and thinks I am crazy for wanting one of these old ones. Everyone has their opinions.
    On another note, I wonder how much R value this old lathe and plaster has compared to sheetrock.....
    Nov 2008
    Kansas
    Ok, well I called by Owens Corning and GreenFiber. Both said I shouldn't have any issues with their blow in material IF my siding is in good shape. They said moisture shouldn't pose any problems.
    Owens Corning was a professionally installed product, GreenFiber can be purchased at Lowes and HD, so that is the option I would choose.
    I guess my last question is how do you determine if/when moisture might be a problem? They did ask me where I lived....
