Question,
Am I allowed to change a 12 gauge circuit to a 14 gauge lighting circuit? I would expect the other way to be an absolute no no.
Thanks in advance
Question,
Thanks in advance
Only if the breaker was a 15A breaker.
14awg = 15A
12awg = 20A
Why would you even consider that?
http://www.inspectpa.com/forum/forum.php
My answers are based mostly on the ICC codes. Advice given is my personal opinion and every person performing work should acquire a permit from his/her jurisdiction and get the work inspected. My opinions are not directions to follow for DIYs or professionals
Yes obviously. Just wanted to know if it would pass inspection if he saw 2 different gauges even though the breaker was still 15amp.
TY
Sorry,
I didn't answer your question.
Well the house was rewired with 200 amp before I bought it and I see 2 cases of it done. I guess it was cause the installer had extra 3wire in 14 that he used instead of getting more 12/3. Kind of cheap. I plan to replace it when I redo that room so if I evern need to change 20amp I will be set in the future.
I would ensure the 12 awg in your panel is clearly labeled "warning connected to 14awg wire, must be protected by 15A breaker"
Yes, I have seen this done, and I don't know why they did it either. It is wrong. You can have a smaller gage wire connected to the 12gage and maintain 20A protection, but only if that smaller gage wire feeds (and is attached to by the manfacture) a UL approved fixture (i.e. hanging lamp with 16 gage cord)
What do you mean it was because he had an extra 3rd wire in the 14? When I hear things like that, I think MWBC, use due caution.
Jamie
I feel the installer used 14/3 (Cause he had it on hand) to wire a ceiling fan instead of purchasing more 12/3 to keep the gauges the same. He cheaped out.
Is this really allowed? There's no danger of overheating?
Gabe
Don't follow my advice, I only know a thing or two about a thing or two.
What do you want to do?
Put a 15a breaker (1800 watts) on 12g wire
--allowed, but as stated - why? breakers are the same $$
You can hook up lighting to a 12g circuit (2400 watts)
Do you want to run 14g wiring now to lights from a 12g circuit?
I would never mix wiring in a circuit, not sure about code on that
The problem is when someone looks at the wire in the breaker panel, sees 12g wire & upgrades the breaker to a 20a
The 14g wire may be hidden & unknown
DIY Handyman (not 4 hire)
I have enough to do to my own house
