WV Hillbilly
I have read several threads where people are having problems with sand in their water systems . I just found a website that sells these sand seperators . If these work , might be a solution .
ALL LAKOS SAND SEPARATORS WILL SHIP DIRECT FROM THE FACTORY.
LAKOS Sand Separators help to protect your home water system against sand from the well, which could plug up sink aerators, or plug up irrigation sprinkler heads. With a LAKOS Sand Separator you will no longer have to drain your hot water tank to remove sand and debris that has fallen to the bottom from your incoming water.
LAKOS also makes sand separators that go into your well to protect your water well pump from pumping sand. This stops the sand problem at the source, before it can cause damage to your submersible pump.
