Washing machine standpipe???
Master Brian
DIY Senior Member
Kansas
What is the correct height for a standpipe? Does this change for a top load to a side load machine?
I am looking at moving my washing machine to my basement, I currently have high efficiency top load unit, but when it goes out, I'll probably get a front load unit. What about sitting the front load unit on one of those pedestal stands, does that change anything?
My drain is 2" PVC, going to a sewage ejector pump and it will be vented.
I thought I posted this earlier, but can't find it, so if it is a duplicate, I appologize!
Basement_Lurker
One who lurks
Victoria, BC
I'm not sure if your local codes, but IPC states:
802.4 Standpipes.
Standpipes shall be individually trapped. Standpipes shall extend a minimum of 18 inches (457 mm) and a maximum of 42 inches (1066 mm) above the trap weir. Access shall be provided to all standpipes and drains for rodding.
A traditional top loader as well as a modern front loader both sit on the ground no matter what, so there is no change in standpipe specs for either unit.
Apparently by IPC, raising your washing machine on a platform has no bearing on standpipe minimum height. However for my code, the standpipe must extend above the FLR and be a minimum of 24".
standpipe
In most cases the standpipe has to be above the level of the water in the machine since most do not have a drain valve to prevent the water from going through the hose when the washer fills.
Master Brian
DIY Senior Member
Kansas
That's kind of what I thought, which is actually why I asked. I would think the front loader when installed on a pedestal would create the need for a higher standpipe.
Thanks for the replies.....
