Results 1 to 10 of 10
Thread: copper tubing for propane
    Default copper tubing for propane
    i am installing a new propane fireplace. what kind of copper tubing is sufficient for this? also it will be running to an outside tank, is copper best for this?
    Personally, I'd rather see something stronger than copper. I'm not a pro. I've heard that propane can cause a buildup in copper pipe as well, and eventually plug it through a chemical reaction with the copper. Again, I've not had any experience with this. You may want to call the building inspector and ask what is allowed. While you may not need a permit (depends on where you live), finding out the correct way to do it (not the easiest) should prevail. What does the manual say for the device you are installing? Probably that it must be done to local codes and may not be very enlightening, except to a pro.
    Default propane
    There are many different ways to pipe gas to a fireplace. It depends on the type of fireplace, the type of burner, and many other items, any one of which can be deadly if not done properly. Contact your building department to learn the approved method of installing the gas, and any primary shut off valves.
    Plumber Deb's Avatar
    Idaho
    Default Deb
    I live in an area with alot of propane. I have never seen the buildup problems that jadnashua speaks of. However, code will dictate what you can run, and how deep it will need to be buried and all the other things you need to know besides the approved material.
    I am also a firm believer that gas lines should be run only by qualified licensed professionals. A mistake can do more than get you wet and an explosion can cause damage beyond your own home.
    It scares me to see the words "propane" and "sufficient" used in the same paragraph...
    Deb
    The Pipewench
    Plumber, Contractor, Attorney LonnythePlumber's Avatar
    Wichita, Kansas
    Default Build Up
    I'm pleased to know that Deb has not seen build up in copper lines delivering propane. I have had to dump the green debri out of lines serving water heaters when our jurisdiction still allowed copper gas lines. I thought that included propane lines in addition to natural gas but perhaps not.
    In certain areas of the country ( depends on where the gas came from) the copper is attacked by the h2so4. Copper is not allowed in California on nat., but is OK on propane.
    Idaho
    Default Deb
    Same here. No copper for natural gas, copper okay for propane.
    Deb
    The Pipewench
    Yakima WA
    Default Pipe for propane
    Even if local code allows it, I'd advise using black iron. When something is allowed in some jusisdictions but not in others, a little amber light blinks in my head. Is it because of border line safety or is it some places just haven't updated their codes? Don't know the answer about copper, but why chance it? Black iron is approved everywhere.
    Default variations
    IN some cases it is just a matter of "protecting their turf". In heavily unionized areas such as Chicago, NY, and San Francisco, there are requirements in place that, while possibly better, are no safer than another method, but since the existing procedures are more labor intensive, and may be beyond the scope of DIY'ers they remain is effect.
    Smile copper/propane
    Here in the NE part of PA as well as the SW part of NY the approved method of piping propane is copper pipe. If buried underground it must be at least 24" (2 feet), and the copper tubing must be a sheathed approved underground rated tubing. Here it costs $100.00 per 60 feet.
