I think it could be made to work, but it will be close and with the extra angles, might be impossible to snake out if something did get clogged. You normally don't want too many angles in the line that close together. See what the pros here think...
You may also end up with the toilet a little higher to accommodate the bends in the line. A wall hung toilet usually needs a 6" deep wall (at least) to have enough room for the drain.
