Ever since I replaced my washer shut off valves on both the hot and cold sides.These new shut off valves are 1/4 turn with arrestors built into them out of the box.
Whether the valves are on or off they seem to have created an unusally loud noise of water flowing when the toilet is flushed and fills back up with water.(loud enough to be heard if you stand outside in the front yard with the front door closed) I am temted to try and track down some older type valves as used to be on the supply lines, for the washer. Thanks for all the replys and advice in advance!
